USRP Software Radio
MPMD Error
etriadmin@etriadmin-ThinkStation-P3-Ultra:~/Downloads$ uhd_image_loader --args type=x4xx,mgmt_addr=192.168.20.2,fpga=X4_200
[INFO] [UHD] linux; GNU C++ version 13.2.0; Boost_108300; UHD_4.6.0.0+ds1-5.1ubuntu0.24.04.1
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.20.2,type=x4xx,product=x410,serial=329C697,name=ni-x4xx-329C697,fpga=X4_200,claimed=False,skip_init=1
[INFO] [MPMD] Claimed device without full initialization.
[INFO] [MPMD IMAGE LOADER] Starting update. This may take a while.
[INFO] [MPM.PeriphManager] Installing component `fpga'
[INFO] [MPM.PeriphManager] Installing component `dts'
[INFO] [MPM.RPCServer] Resetting peripheral manager.
[INFO] [MPM.PeriphManager] Device serial number: 3298199
[INFO] [MPM.PeriphManager.ClkMgr] Using Clock Configuration:
DB0: Master Clock Rate: 245.76 MSps @Converter Rate 2.94912 GHz
DB1: Master Clock Rate: 245.76 MSps @Converter Rate 2.94912 GHz
[INFO] [MPM.PeriphManager] Initialized 2 daughterboard(s).
[INFO] [MPM.PeriphManager] init() called with device args `boot_init=True,clock_source=internal,time_source=internal,initializing=True'.
[INFO] [MPMD IMAGE LOADER] Update component function succeeded.
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.20.2,type=x4xx,product=x410,serial=329C697,name=ni-x4xx-329C697,fpga=X4_200,claimed=False,find_all=1
[INFO] [MPM.PeriphManager] init() called with device args `find_all=1,fpga=X4_200,mgmt_addr=192.168.20.2,name=ni-x4xx-329C697,product=x410,clock_source=internal,time_source=internal,initializing=True'.
[ERROR] [MPMD::MB_IFACE] Unable to look up clock '1'. Invalid index
[ERROR] [RFNOC::GRAPH] Caught exception while initializing graph: LookupError: KeyError: Unable to look up clock '1'. Invalid index
Error: RuntimeError: Failure to create rfnoc_graph.
How can I evade this error?
Message 1 of 1
(576 Views)
