USRP Software Radio
Maximum ratio combining technique (MRC) using usrp
If a USRP antenna receive two different signal of same carrier frequency then how it will detect them and add them?
simply I am trying to impelment MRC using usrp
(5,313 Views)
Take a look at this white paper. I think it will help answer some of your questions.
http://www.ni.com/white-paper/13878/en/#toc2
RF R&D
(5,287 Views)
MRC has already been implemented on USRP.
Find the below link for the example code for 2X2 MIMO in which the receiver part is using MRC.
https://decibel.ni.com/content/docs/DOC-21751
(5,235 Views)
Thanks for your replies guys, I will try to implement the code.
(5,231 Views)
