USRP Software Radio
Missing dependency: NI::USRP::niUSRP.udr::niUSRPClass
Hi,everyone:
   I opened a project on labview nxg 3.0 and saw the following error message.What is the cause of the error.
   I installed labview nxg 3.0 and labview nxg 4.0 at the same time, and installed 4.0 first. There will be this error when opening on 3.0, but there is no error when opening on 4.0依赖缺失en.png
(3,604 Views)
Similar problem over here. I can open a project without any problem in NXG 3.1 but in NXG 5.0 it opens with missing dependency errors. The problem also exist among all 25 students.
(3,494 Views)
I am having same problem with Labview NXG 5.0.0 and NI USRP 2930. My error pictures are attached. I hope some kind soul will post solution.
(3,437 Views)
I have a similar problem with Labview Communications 5.0. I tried to use the USRP models  2901, 2920 and 2954 , in all cases I got the same errors. I updated USRP drivers and did a clean install without success. However, Labview Communications 4.0 still works fine.
(3,400 Views)
I am having the same problem with the exact same error messages, but I am using LabVIEW NXG 5.0.
(3,368 Views)
