USRP Software Radio
Modify USRP 2954R firmware to do a task autonomously
Hi everybody,
i'm working with a USRP 2954R with PXI cable using LabVIEW 2018 32bit and LabVIEW FPGA; i've modified the template Simple Streaming (i used this as reference one) both in Sw and Hw; in particular, i've modified the main FPGA VI in a way that it generate a signal samples in the Hw level to transmit them directly; I would like to modify the firmware device (or the FPGA image) to do this task independently and as soon as i turn on the device. Is that possible? And how can i do??
Thanks for your answers!
AP
(2,449 Views)
Unfortunately, it is not possible to make it work without the host interface.
For a standalone device you may consider the USRP-2974.
https://www.ni.com/en-us/support/model.usrp-2974.html
(2,289 Views)
