USRP Software Radio
N210 MIMO configuration
Hi all,
I'm trying to use 2 USRPs to use 1 TX and 2 RX at the same time.
I connected both with mimo cable but thare's something that I don't understand.
When I use the command uhd_find_devices I get
-- UHD Device 0
Device Address:
    type: usrp2
    addr: 192.168.10.2
    name:
    serial: E6R22NBUP
-- UHD Device 1
Device Address:
    type: usrp2
    addr: 192.168.10.2
    name:
    serial: E6R22NBUP
2 devices with the same address, and same serial.
I'm using GNUradio, and I can't get any signal in the USRPs Sources (RX). The files generated by the File sink are just empty (0 Kb).
I'm not sure about what should I do now.
In annex my configuration for the USRP source.
(5,980 Views)
I have changed the IP address of one of the USRPs. However I still can not get any data from the USRP Source -> File Sink.
(5,968 Views)
Hi Rafael,
It makes sense that the IP addresses were the same you can see that the default IP address is 192.168.10.2 in section 3 of the following Whtie Paper http://www.ni.com/white-paper/13880/en/. I'm glad that you were able to change the IP address of the second device. I would recommend looking at section 5 of the same White Paper. Have you tried running examples to see if you get the same result?
Scott B.
AE NI
(5,950 Views)
Hi Skirpt,
Thanks for your reply. For my project I'm usgin GNURadio instead of MATLAB or LABview.
While using the MIMO cable I couldn't use both antennas in each USRP. When I tryed to use both USRPs sending and receiving data in each antenna the receiving signal was void. However when I tried to just read from both USRPs it was aparently working fine.
(5,922 Views)
Rafael,
Have you ever been successful in sending data? It seems that is where the issue is originating.
Scott B.
AE NI
(5,903 Views)
Accepted by topic author rafael.acurcio
Skirpt,
After some tests I finally managed to use both USRPs using the MIMO cable.
Thanks for your help
(5,895 Views)
