USRP Software Radio
N210 lo ofset turning off
I have problem with n210. problem is in this
 Device: USRP2 / N-Series Device
     |     _____________________________________________________
     |   |       M board: N210r4
     |   |   hardware: 2577
     |   |   i p - address: 192.168.10.2
     |   |   sub net: 255.255.255.255
     |   |   gateway: 255.255.255.255
     |   |   g p s do: none
     |   |   serial: E4R22N6UP
     |   |   F W Version: 12.4
     |   |   F P G A Version: 11.1
     |   |   Time sources:  none, external, _external_, m i m o
     |   |   Clock sources: internal, external, m i m o
     |   |   Sensors: m i m o_locked, ref_locked
     |   |     _____________________________________________________
     |   |   |       RX D S P: 0
     |   |   |   Freq range: -50.000 to 50.000 MHz
     |   |   |       RX D S P: 1
     |   |   |       RX D board: A
     |   |   |   ID: RFX900 (0x0025)
     |   |   |   Serial: EFR12V0R9
     |   |   |     _____________________________________________________
     |   |   |   |       RX Front end: 0
     |   |   |   |   Name: RFX900 RX
     |   |   |   |   Antennas: TX/RX, RX2, CAL
     |   |   |   |   Sensors: lo_locked
     |   |   |   |   Freq range: 750.000 to 1050.000 MHz
     |   |   |   |   Gain range PGA0: 0.0 to 70.0 step 0.0 dB
     |   |   |   |   Bandwidth range: 40000000.0 to 40000000.0 step 0.0 Hz
     |   |   |   |   Connection Type: Q I
     |   |   |   |   Uses LO offset: No
     |   |   |   |       RX Codec: A
     |   |   |   |   Name: ads62p44
     |   |   |   |   Gain range digital: 0.0 to 6.0 step 0.5 dB
     |   |   |   |   Gain range fine: 0.0 to 0.5 step 0.1 dB
     |   |   |       TX D S P: 0
     |   |   |       TX D board: A
     |   |   |   ID: RFX900 (0x0029)
     |   |   |   |       TX Front end: 0
     |   |   |   |   Name: RFX900 TX
     |   |   |   |   Antennas: TX/RX, CAL
     |   |   |   |   Gain Elements: None
     |   |   |   |   Connection Type: IQ
     |   |   |   |   Uses LO offset: Yes(how to change this)
     |   |   |   |       TX Codec: A
     |   |   |   |   Name: ad9777
thank you in advance.
(3,329 Views)
Reper,
This is Ali from Applications Engineering at National Instruments. Are you interested in changing the value of the Use LO Offset or would you like to remove that option from the rest of the codeset?
Ali S.
(3,311 Views)
Hi i am interested in both changing lo ofset and removing it . Thank you in advance
(3,303 Views)
Reper,
 What software is this being done in?
If it is NI Configuration Utility, then there should be a property node to disable the item. If it is Ettus Software then that could require more detail.
Ali S.
(3,292 Views)
Can I reset this by pressing S2 button? Also what do i need to write in utilities command prompt (shift+right click then open command window here )? Can i write this two N210->set Frequency(SOAPY_S D R_TX, 0, center Freq, {"OFFSET":"0"}) or
N210->set Frequency(SOAPY_S D R_TX, 0, "RF",1455e6);
N210-> set Frequency(SOAPY_S D R_TX,0,"BB",0);
to reset frequency offset or do I need to write something else? I am using Microsoft windows
(3,248 Views)
