USRP Software Radio
NI 2921 daughter board compatibility
Please tell me the method to check the compatibility of 782761-01 SBX USRP Daughterboard (400 MHz - 4.4 GHz) with USRP NI 2921.
(3,010 Views)
Can you please elaborate?
Do you wish to use the SBX daughterboard on the USRP NI 2921 motherboard?
If so, I think you need to email support@ettus.com.
(2,966 Views)
Actually, I just want to confirm if sbx daughterboard can be replaced  with NI USRP-2921 default daughterboard, as the default daughter board does not support the GSM frequency range.
(2,950 Views)
Yes, that should work if you're using an SBX-40 daughterboard. It'll void your warranty to open up the enclosure to replace the boards, however.
(2,943 Views)
