USRP Software Radio
NI-USRP 14.1 release , which UHD release is used ?
Hi
i have a USRP X300  that i want to use with the NI-USRP 14.1 driver release & labview 2015(64)
when installing the driver i get a images directory , but no images for X300 ,only image for X310 (usrp_x310_fpga_HGS.lvbitx)
but i guess i can't use this image ?
which UHD release is used for this driver ? UHD 003.009.??? ,
can i use a normal UHD FW release with the 14.1 driver ?
(4,322 Views)
You cannot use the x310 image (usrp_x310_fpga_HGS.lvbitx) with the x300 device.
NI-USRP does not offcially support the x300 devices, only the x310.  NI-USRP is also not associated with a specific release of UHD.
The closest UHD release to the NI-USRP 14.1 release would be release_003_008_004.  If you got the usrp_x300_fpga_HGS.lvbitx image from that release and placed it in the
   C:\Program Files (x86)\National Instruments\NI-USRP\images
it might be compatible with the driver, but this is not supported and has not been tested.
(4,309 Views)
ok , thanks
i just tested with different releases , and "uhd-images_003.008.005-rc1" did allsow work fine.
(4,294 Views)
