USRP Software Radio
NI-USRP 2952R failure connected to the PC
Hello everyone,
I am trying to connect the USRP-2952R to my computer using PCIe X4 cable , later it was working well but now it seem that when power on the USRP and then power on the PC the windows cannot open , I try to use another USRP with the same version it works good !
is someone face this problem before?
(1,441 Views)
I also have two of them, and used PCIe cables, most of the time it worked well. But once there was an update that made it not working any more. So I reinstall the driver and then they worked. So my case clearly indicated the update process went wrong. Some other possibilities could be the configuration of the USRP.
There are new update and driver version of 20.5, both windows 10 and 11 works for me on IQ collection and analysis, although NI website stated windows 11 not yet supported.
The above version does support the data collection using NIC port, worth trying, but I did find that even using 10Ge cable, they are less reliable (need min of cat 6 Ethernet cables, and correct port for the correct IP address setup) and often met IQ out of sequence error when fs is high.
If I were you I would try to reinstall the SW/FW on the USRP.
Good luck!
(1,206 Views)
