USRP Software Radio
OFDM MIMO 2x2 with NI USRP 2920
Hello,I am also very interested in 2*2MIMO with OFDM, could you share the code with us? Thanks a lot!
Message 11 of 14
(3,581 Views)
Hi Erik,
I'm doing a MIMO relay to be as a bridge between TX and Rx. The relay concept is using the RX and then connect to TX as the output. Can i used the same USRP (NI USRP 2922) to be as RX and TX. Here I attach the relay VI.  ( fyi, i am using different the centre frequency  and delay and timeout so that it can workout but it seems not function at TX part but at RX it function well).
Thank You,
Mardiah
Message 12 of 14
(3,519 Views)
Message 13 of 14
(1,493 Views)
Hi Pixus,
I'm also building a OFDM MIMO 2x2 with USRP 2920. And my problem is same as yours. You said that it will works if change some text string. But I can't find the text string like you said (0,1). Which string should I change ? and where are they?~o~
If it's hard explain with words,could you give me a picture?
Thanks a lot
Leo
Message 14 of 14
(1,222 Views)
