USRP Software Radio
OOK modulation & demodulation
Hello everyone,
I'm new using Labview and I need help to develop an OOK modulator and demodulator VI. I will run this files under the USRP NI myRIO.
Could anyone help me?
Thanks 🙂
(2,954 Views)
The NI-USRP driver ships with a few Modulation Examples which use the Modulation toolkit to transmit and receive wave-forms with different modulation schemes using USRP devices. You may be able to use them as a starting point to create your OOK application.
I didn't however the myRIO part in your post. Can you elaborate?
"I will run this files under the USRP NI myRIO"
(2,926 Views)
