USRP Software Radio
PSK Rx. receiving bits are in error
Hello.I am using PSK Tx.vi and PSK Rx.vi for BPSK signal bits transmission and receiving. The problem is that I am not getting correct bits at the receiver. Is there any way I can receive correct bits at the receiver.
I have attached a screenshot of what bits I am transmitting and receiving.
I am using one USRP 2920 for transmission and receiving.
(2,708 Views)
I posted on the other thread as well, but a new post is probably the best place for this question so I'll copy my response here:
Could you post another screenshot showing both the Tx and Rx front panels so that I can see the settings for both?  Are these USRPs cabled or are you using an antenna?  If using an antenna, check with a cabled connection to verify that you get the correct bits.  Also, is this only happening at specific frequencies or with specific settings?  Have you been able to configure the USRPs to get the correct bits with different settings?
Jon F.
Technical Support Engineer
(2,666 Views)
Thank you so much for replying.
I will get back to you with all the answers.
Actually my teacher has told me to create a scenario on LabVIEW and check the results first before going to USRP's so i am working on that now.
(2,661 Views)
