USRP Software Radio
Packet transmission using two usrps 2920
Hello...
we are using the packet transmission example with slight modification to transmit a series of bits.
we were successful in transferring the bits using a single usrp as a transmitter as well as a receiver.
but when we tried it on two different usrps with different host pcs, the bits could not be received. there were no other errors. the distance between the two usrps was kept very small.
we tried it with antenna as well as the loop back cable.
P.F.A the modified vis.
thanks
(2,552 Views)
What are your TX/RX Parameters for the transmit and receive VIs? I'm asking because the default TX frequency is set to 2.5G and default RX is set to 915M in the VIs you linked.
Also, for troubleshooting sake, I'd try the original example as well so make sure there isn't an issue with the modifications. I know you said it worked with one USRP in loop back, but I think this would be a helpful data point as well.
(2,530 Views)
