USRP Software Radio
Problem with connecting USRP to MATLAB
I have a problem in connecting the USRP to MATLAB. When I use  "NI-USRP Configuration Utility" I can see that USRP N210 is connected correctly and the IP address is: 192.168.10.2 but when I command "findsdru" in MTLAB, I get the following:
However I'm sure it's connected. Can anyone help me on this matter?
--Kash
(3,373 Views)
Hello khdl!
I would recommend you speak with Ettus Support as you are using an Ettus branded USRP (N210) without NI Software.
Stephen Chan
(3,328 Views)
Stephen,
I will, thanks.
--Khdl
(3,325 Views)
