USRP Software Radio
Push the high IQ sampling rate for multiple synchronised USRP 2943R with Network Ports configuration
HI Muffin,
Thanks for your reply.
1. If I move the data fetch in the red circular, it will report the same error as I posted before. To be honest, I think the out loop data fetch will be matter.
2.  I tried the USRP_Rx_continous_8_channel.vi. For this VI, with clock and and PPS from octcolck. I can run this VI in 5M IQ sampling rate.
3. I feel like with network port configurawtion and corresponsing driver, it may never achieve 8 synchronized channel on 40 MHz IQ sampling rate.
I notice that Labview seems like provided different blocks (or drover) for USRP and USRP RIO. WIthout accessing to the FPGA, high IQ rate cannot be achieved.
Cheers,
Bo
Message 11 of 13
(1,394 Views)
True_Boombo,
How are you connecting to the USRP RIO? Through Ethernet or through a PCIe connection?
And what happens when you increase the IQ sampling rate on the example? Does it give you an error?
Message 12 of 13
(1,385 Views)
Hi Muffin,
I am connecting 4 USRP 2943Rs with 2 Network card, each card has 2 ports.
If I increase the IQ sampling rate, it simple report overflow error (the solutions are: reduce sampling rate, increase number of samples per fectch.....).
Cheers,
Bo
Message 13 of 13
(1,382 Views)
