USRP Software Radio
Python GUI and usrp 2920
My name is Omar Nahhas, I'm a current student at North Carolian state university. I have been working with the USRP-2920 to transmit signals using the UHF band range
I have a python gui that generates 2-3 bytes of code or a simple text file, I wondering if there is anyway to get the USRP-2920 to transmit the signal for me
would TCP/IP socketing work for this or not?
Thank you,
Omar
(5,545 Views)
You could access the NI-USRP API C interface from Python.
There is some information on doing this here:
https://docs.python.org/2/library/ctypes.html
You would want to call into niusrp.dll in the sytem directory (assuming you're using Windows).
Header files with the exported methods are here:
C:\Program Files (x86)\National Instruments\NI-USRP\includes
The import library is here:
C:\Program Files (x86)\National Instruments\NI-USRP\lib\msc
(5,527 Views)
