USRP Software Radio
RFNoC Getting Started - Warning message
I've followed the instructions from here: https://github.com/EttusResearch/uhd/wiki/RFNoC:-Getting-Started
I did a fresh install of everything (UHD, GNURadio then gr-ettus as well as the FPGA image) from the GitHub source on a fresh install of Ubuntu 14.04.
The first warning I get is the following when I run gnuradio-companion:
"Warning: XML parsing failed:
Key "in_type" already exists in params
Ignoring: /usr/local/share/gnuradio/grc/blocks/uhd_rfnoc_streamer.xml
Warning: Block key "uhd_rfnoc_streamer" not found when loading category tree."
Do I need to worry about this warning?  Phospor seems to run but every time I stop and re-start it I get a "timeout on chan 0".  When I power-cycle the X310 everything works again.  I'm guessing this behavior is probably unrelated to the warning message, but want to make sure the warning won't cause other issues down the road.
Versions
UHD_003.010.rfnoc-314-gf773e72b
GNU Radio Companion v3.7.9.1-73-g64f3b70c
FPGA bitfile built from rfnoc-devel branch yesterday
gr-ettus master branch from yesterday
(4,407 Views)
Hello!  This forum is for LabVIEW based support.  Please join the USRP-Users mailining list for RFNoC related questions.
http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
Thank you,
Erik
(4,405 Views)
