USRP Software Radio
Real time FFT resolution
Good day to every body Smiley Happy
I'm playing with an ETTUS B200 mini for doppler frequency monitoring.
To analyze the spectrum in real time, I'm currently using uhd_fft.py (gnuradio application). The problem is that the maximum fft sample number is 4096, while I need 2^14 samples.
I tried to investigate into the c++ files (invoked by uhd_fft.py), such as freq_sink_c_impl.cc (https://github.com/gnuradio/gnuradio/blob/master/gr-qtgui/lib/freq_sink_c_impl.cc) whose line 216 describes the following action:
216 throw std::runtime_error("freq_sink: FFT size must be > 16 and < 16384.");
The problem seems to be hard without the whole file list to be recompiled....
Would anybody help me ?
Thank you very much!!
Grazie,
ciao
(3,285 Views)
Hi Frank,
I recommend you as you propose to recompile all the files..otherwise is hard to understand the behavior of the code used...
Then, try to increase the fft sample number...
BR,
Andres
Andrés Alvarez
Staff Technical Support Engineer
CLD, CTD, CTA
(3,258 Views)
Hi Franks,
Did you try to recompile all the files?
Andres
Andrés Alvarez
CLD, CTD, CTA
(3,246 Views)
Hi Andres, thank you for your response. I have been on business trip and I could see your message just now. Honestly speaking I'm not sure which files should be recompiled. There are many dependencies and it looks like a juniper bush -:)
Do you have already experienced the same problem?
Further, before recompile I guess I should modify the part of codes (in one or more file, cc and h) where the limit to 2^12 is set. What do you think about ?
Thank you again for your help
Have a nice day
(3,227 Views)
Hi Frank,
Unfortunately I do not have experience with this kind of problem 😞
But I think is very interesting.
Try to recompile the file and then see what happens.
Have a great day!
Andrés Alvarez
CLD, CTD, CTA
(3,215 Views)
