12-23-2014 06:24 AM
We're testing record and playback using USRP-2920( LV 2013sp1, NI-USRP 14)
To test it, we downloaded record and playback example code.
Signal source is a function generator outputting 6 MHz bandwidth 8 VSB modulation signal.
USRP Rx parameters are center = variant / gain = 0 / IQ rate = 25MHz and Tx parameters are center = same as Rx center / gain = 0 / IQ rate = 25MHz
The problem is... in low carrier frequency like 70MHz, quality of playback signal is great.
But in high carrier freqency like 2.2GHz, SNR and signal power dropped significantly i.e. they tend to drop as carrier frequency goes high.
And the strange thing is as carrier frequency is increased, a small peak on the center is increased as well.
Please check the attatched file to see the tendancy.
So.. my question is why is this tendancy occures?(we tested another USRP and the result was same as before)
and what should we do to reduce this effect?
Youngmin
01-02-2015 02:10 PM
I suggest a couple of things:
Thanks.
