USRP Software Radio
Serial communication on E320
Hi all! Has anyone used a USRP device to communicate with a microcontroller through serial? Right now I have a microcontroller with just a serial port and need to send a bunch of data through it to an E320 device where the data would be modulated and transmitted through one of the TX channels. Is this possible? I've been checking the documentation of the E320 and although it has serial ports available, I think they are meant for other purposes and can't be programmed like the serial port of an Arduino
(350 Views)
In the past, I have used a USB serial cable connected to a USB port on E320 as tty.
(321 Views)
