USRP Software Radio
Simple Resample.vi file missing
Hi!
I am a student and using LABView 2015 (64-bit) along with USRP-2920. i am trying to attempt Example 2A (Demodulate FM Radio) from student manual but it shows that (Simple Resample.vi) file is missing. Please tell me which driver is missing in my system. Screenshots are attached.
(3,072 Views)
You would need the USRP driver to get access to that function. It can be found here: http://www.ni.com/download/ni-usrp-15.0/5679/en.
Let me know if that helps!
Best,
Sunayna R.
Applications Engineering
(3,037 Views)
Thank you for your reply Sir!
I have already installed NI-USRP 15.5 in my system. Also tried the NI-USRP 16.0 but the issue is still there.
(3,029 Views)
It looks like that VI isn't actually included in the driver but the actual supporting files for the exercises as part of the course (see image). Do you see that file anywhere in the folder you got the exercises from?
Sunayna
Sunayna R.
(3,017 Views)
