USRP Software Radio
Simple bit encoder
I have to make a simple communication system with from Labview and URRP. Fro one side I have to send randomly generated bits in terms of voltages and I have to decode the signal to get and display the exact sequence. I have to complete this within next two days. I have tried a lot but failed. Will someone please help me???
(6,018 Views)
Also if not complete can anyone suggest ways to generate raised cosine pulses according to incoming bits??
(6,014 Views)
Check out the packet based digital link on the second page.
https://decibel.ni.com/content/groups/ni-usrp-example-labview-vis?view=documents
(6,012 Views)
Thank You for your help. But I need to make 1 of my own as its far more complicated than anything I can handle.
I have tried making one vi but it is not giving the desired result.
For the problem statement mentioned above what I had thought was:
 A random generator is generating numbers 0 and 1 which I am using to decide the amplitude of raised cosine pulse generated. For each number generated I am sending 10 pulses by putting pulse generator in while loop. Also I am putting a delay (wait)  in the loop in accordance to the time period of pulse inorder to avoid ISI. But while running the code I am getting error 'buffer empty'.
Also I could not find any source to generate raised cosine pulse. I used generate formula waveform vi, but while transmitting through usrp, coerced gain was coming zero. I believe pulse and function differ.
Please help.
(5,995 Views)
This is the vi I am working with.
(5,993 Views)
