USRP Software Radio
Simulating RFNoC blocks in GRC
Hi All,
  I'm starting the process of using GNU Radio to operate an X410 board.  As is almost always the case, I'm trying to do a quick design that uses RFNoC blocks in GRC in simulation only.
So, I'd like to just simulate the RFNoC block operation without connecting to a hardware board.  However, there's no info (that I've found) on how to run in simulation mode with the RFNoC blocks.  Can somebody point me to a relevant tutorial or description?
DVB
Message 1 of 1
(121 Views)
