USRP Software Radio
Spatial Multiplexing using 2 USRP pairs
I have two pairs of USRP 2920, 2 MIMO cables and 4 antennas. I want to create a simulation of Spatial Multiplexing. Is it possible to transmit from two USRPs connected by a MIMO cable to a third USRP, without using external PPS in signal or REF clock of any kind? All 3 USRPs will be connected to my PC with a switch. From my previous work of Alamouti scheme, I figured that it is not always possible to synchronize two USRPs to a third one without extra hardware.
Was there any example posted about SM? couldn't find any.
In another topic, is there any working example to a simulation of LTE system or WIFI to the USRP 2920?
Thank you in advance,
Dor
(4,389 Views)
Sure, but typically you need to sync the two transmitters in a MIMO system sync the frequencies (prevent frequency offset) and sync the sample clocks.
http://www.ni.com/white-paper/14311/en/
(4,375 Views)
Thank you for the fast replay.
Does it mean I need to buy external hardware to connect to the USRPs?
(4,371 Views)
