USRP Software Radio
Synchronize tx and rx
Hi everyone.
I started to study how to use USRP-N2920 and Lab VIEW recently.
There is a question that I can’t know how to do even though use Web search.
I want to run TX and RX in same time with same VI and same device (use TX1 and RX2).
This system sent TX signal to a plant and receive RX signal form the plant.
My purpose is measurement the phase difference between TX and RX, but the result change each time when I run my VI such like the attached program.
I think this problem is caused by that my VI doesn't synchronize between TX and RX, so that I can't measure accurately the time different the TX sample and the RX sample.
I want to start TX block and RX block same time.
Please teach how to synchronize TX and RX with same VI and same device.
Best Regard.
McGuinness
(6,470 Views)
hi, I'm not expert on USRP nor do I have one,
but in general I think you need to synchronize the two channels with some kind of start trigger.
I found triggered aquisition example on "niUSRP EX Rx Continuous Sync.vi", and edited your vi based on that.
Can you try to see if it works?
(6,266 Views)
suncraft
Thank you for your reply and your vi!
I tried to work your vi, but it display an  error such bellow.
"niUSRP Write Tx Data (CDB).vi<ERR>Underflow: the Tx buffer was emptied before new data was provided. "
I changed some parameters such as IQ rate, waveform size, start trigger time.., but It didn't work well.
I appreciate your suggesution.
(6,246 Views)
me too I have the same problem
(6,128 Views)
