USRP Software Radio
TX Frontend: 0 ... Connection Type: QI
Hi all, I have problem in syncronizing tx and rx in full duplex mode. When I run the uhd_usrp_probe, I got:
C:\Program Files (x86)\National Instruments\NI-USRP\utilities>uhd_usrp_probe
  _____________________________________________________
|       Device: USRP2 / N-Series Device
|   |       Mboard: N210r4
|   |   hardware: 2577
|   |   mac-addr:
|   |   ip-addr:
|   |   subnet:
|   |   gateway:
|   |   gpsdo: none
|   |   serial: F4A7C2
|   |   FW Version: 12.4
|   |   FPGA Version: 11.1
|   |   Time sources:  none, external, _external_, mimo
|   |   Clock sources: internal, external, mimo
|   |   Sensors: mimo_locked, ref_locked
|   |     _____________________________________________________
|   |   |       RX DSP: 0
|   |   |   Freq range: -50.000 to 50.000 MHz
|   |   |       RX DSP: 1
|   |   |       RX Dboard: A
|   |   |   ID: CBX (0x0067)
|   |   |   Serial: F5F043
|   |   |     _____________________________________________________
|   |   |   |       RX Frontend: 0
|   |   |   |   Name: CBX RX
|   |   |   |   Antennas: TX/RX, RX2, CAL
|   |   |   |   Sensors: lo_locked
|   |   |   |   Freq range: 1200.000 to 6000.000 MHz
|   |   |   |   Gain range PGA0: 0.0 to 31.5 step 0.5 dB
|   |   |   |   Bandwidth range: 40000000.0 to 40000000.0 step 0.0 Hz
|   |   |   |   Connection Type: IQ
|   |   |   |   Uses LO offset: No
|   |   |   |       RX Codec: A
|   |   |   |   Name: ads62p44
|   |   |   |   Gain range digital: 0.0 to 6.0 step 0.5 dB
|   |   |   |   Gain range fine: 0.0 to 0.5 step 0.1 dB
|   |   |       TX DSP: 0
|   |   |   Freq range: -200.000 to 200.000 MHz
|   |   |       TX Dboard: A
|   |   |   ID: CBX (0x0066)
|   |   |   Serial: F5F043
|   |   |   |       TX Frontend: 0
|   |   |   |   Name: CBX TX
|   |   |   |   Antennas: TX/RX, CAL
|   |   |   |   Connection Type: QI
|   |   |   |       TX Codec: A
|   |   |   |   Name: ad9777
|   |   |   |   Gain Elements: None
My question is, is it normal having connection type: QI?
Message 1 of 1
(16,534 Views)
