USRP Software Radio
TXs Phase offset in single USRP
I have recently started a project  with USRP 2945R. I write the same signal to both TX channels but whether by using internal/external clock source there exists a phase offset between the transmitted signals that I can see on the oscilloscope. This offset changes randomly each time I do the measurements. I wanted to know if there is a way to calibrate the LOs to compensate this phase offset?
(3,385 Views)
Ni NafJ,
There is some amount of random phase offset that will occur every time you tune the LOs. From Ettus' documentation: "After tuning the RF front-ends, each local oscillator may have a random phase offset due to the dividers in the VCO/PLL chains. This offset will remain constant after the device has been initialized, and will remain constant until the device is closed or re-tuned. This phase offset is typically removed by the user in MIMO applications, using a training sequence to estimate the offset. It will be necessary to re-align the LOs after each tune command."
Cason
NI Applications Engr.
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
(3,360 Views)
Is there any way to measure the phase offset between the LO's in Labview VI?
(3,113 Views)
