USRP Software Radio
The delay of USRP Driver
I tested  the delay of latest USRP Driver 1.2 (download from  http://www.ni.com/download/ni-usrp-1.3/4711/en/ )  and found niUSRP Abort. vi  has unaccept delay of 200 ms ... much larger than the same vi in the older USRP Driver 1.2, it is very  unaccountable .
What is more , it seems the latest Driver 1.2 has many problems such as LV program crash and cannot be stopped. I hope  these problems will be solved.   Thanks a lot
(6,286 Views)
I use the latest USRP Driver 1.2 with LV 2012
(6,285 Views)
I also want to know why there is the delay of 200ms in niUSRP Abort.vi . Is there any possibilty  to overcome this delay or reduce it to less than 1ms. I really hope that someone can give the answer to this problem.
(4,783 Views)
Try this newest version (15.0) and let us know if the crash persists and if you observe the same delay in Abort.
http://www.ni.com/download/ni-usrp-15.0/5679/en/
(4,775 Views)
Okay, Thank you for the reply Sir. I will give it a try and let you know if it can solve the problem or not.
(4,763 Views)
I try to update the driver as you recommended me before but the delay 200ms in the niUSRP Abort.vi still not solved. Is there another options to overcome this problem?
(4,699 Views)
