USRP Software Radio
Turn on USRP1 Tranceiver
Hi
How i can turn on USRP1 Transceiver manually with its built in 64MHz clock
Thanks in advance
Regards
Usama
(5,939 Views)
I am slightly confused about your question. Are you asking how you can use the 64MHz clock as the sample clock for the ADC during an acqusition?
Also, can I ask which driver and Application Development Environment you are using to control your USRP1? I'm asking this because NI does not support the USRP1 with our USRP driver set.
You can refer to Ettus's website for support related questions on the USRP1.
http://www.ettus.com/contact
Thanks!
Cameron T
(5,921 Views)
Thanks for replying
Basically i am building openbts2.8 on my USRP1. but this does not support USRP1 with its built in clock(64MHz). To run it, i have to turn on USRP1 transceiver  manually. an then run openbts to work it properly. so i need method to turn on USRP1 transceiver
Usama
(5,913 Views)
