USRP Software Radio
Tx Rx IQ diagram won't resolve
I'm using two NI USRP-2901s with the Modulation Toolkit Examples Tx PSK and Rx PSK.
When I first used this, I could transmit QPSK with no filter and receive with no problems. I left it for a while and returned to try again and for some reason the received IQ constellation won't resolve and seems to pulse in bizarre patterns or in a circle. I've tried changing the parameters and have checked that the parameters match but to no avail.
Please help!
(2,648 Views)
Do you still get the problem if you turn off the USRP for a bit and on again?. I suspect that an LO Drift might be causing your issue.
Abdullah
(2,592 Views)
