USRP Software Radio
UBX
I probably know the answer to this already, but.....
UBX support in the NI Driver anywhere on the roadmap?
Also....any updates on B200/B210 support?
Brandon
(5,657 Views)
Hi Cochenob
The answer is no yet. As you can find in other discussion forums If you have urgent application needs please contact your local NI field engineer.
Regards
Frank R.
(5,636 Views)
UBX Support is now available for NI USRP RIOs. The newly released NI 2944 and 2954 both use the UBX-160 daughterboard, offering 10 MHz- 6 Ghz frequency range and 160 MHz of real-time bandwidth. The 2954 also offers a GPS-disciplined oscillator.
(4,457 Views)
Glad to hear it. Does labviewfpga support it ?
(4,441 Views)
Yes. Support is offered in LabVIEW 2015 and LabVIEW 2015 FPGA. LabVIEW Communications support will be released in the future. You will need to use the beta NI USRP 15.5 driver, which is available at ni.com/beta
(4,437 Views)
