USRP Software Radio
UHD Installation
           following instructions at  "http://files.ettus.com/manual/page_install.html", i have downloaded  the installer from             "  http://files.ettus.com/binaries/uhd/latest_release".
           Now, when i unzip the package, i arrive at a folder named  "uhd_3.12.0-release". This folder has many many                 many sub folders and each sub folders has many many many files within.
           So i am unable to follow what do i do? How do i install the UHD from here.
            I think i need step by step instructions.
Thanks a lot,
Vinayak Anant Karandikar
(2,519 Views)
Hi Vinayak,
can you tell us how do you want to install UHD?
As Ettus is stating, they provide also Windows Installers. On the LINK for downloading you sent, there is folder Windows with EXE installer.
I would also say, that users in this forum may help you with USRP and LabVIEW programming.
In case you will have in future more questions about using UHD, ettus can help you much more with better targeted support.
You can reach them on support@ettus.com or you can reach the community on stackoverflow here.
Hope this helps.
Patrik
CTA, CLA
Helping (sharing) is caring!
If the post was helpful - Kudo it.
If the post answered your question - Mark it as Solution.
(2,497 Views)
The problem was solved
(2,454 Views)
