USRP Software Radio
UHD installation error in pybombs trying to install OP25
Hi All,
This is my first post here. I am trying to install the OP-25 software and it uses pybombs to install all versions and dependencies. During the installation of UHD I received a fatal error 12% through.
I brought this up in the OP 25 forum but they said that it was specific to UHD and to ask here.
Here is the complete script that pybombs displayed, the error is near the end.
Please help !!
thanks,
Joe
Script follows (abbreviated due to 10000 character limit):
joe@joe-desktop:~$ ./pybombs install gr-op25
bash: ./pybombs: Is a directory
joe@joe-desktop:~$ cd pybombs
joe@joe-desktop:~/pybombs$ ./pybombs install gr-op25
Settled on prefix: /home/joe/target
Initializing environmental variables...
/home/joe/target/python/:/home/joe/target/lib/python2.6/site-packages/:/home/joe/target/lib64/python2.6/site-packages/:/home/joe/target/lib/python2.6/dist-packages/:/home/joe/target/lib64/python2.6/dist-packages/:/home/joe/target/lib/python2.7/site-packages/:/home/joe/target/lib64/python2.7/site-packages/:/home/joe/target/lib/python2.7/dist-packages/:/home/joe/target/lib64/python2.7/dist-packages/:/home/joe/target/python/:/home/joe/target/lib/python2.6/site-packages/:/home/joe/target/lib64/python2.6/site-packages/:/home/joe/target/lib/python2.6/dist-packages/:/home/joe/target/lib64/python2.6/dist-packages/:/home/joe/target/lib/python2.7/site-packages/:/home/joe/target/lib64/python2.7/site-packages/:/home/joe/target/lib/python2.7/dist-packages/:/home/joe/target/lib64/python2.7/dist-packages/
---------- loading recipes -------------------
Loading recipes ...
Loading recipes ... done
---------- loading recipes finished ----------
checking for gr-op25
False
/home/joe/pybombs/mod_pybombs/sysutils.py:588: RuntimeWarning: tempnam
is a potential security risk to your program
 tmpfile = os.tempnam(d);
TMPFILE = /home/joe/target/fileIUp2rF
WRITE PERMS OK /home/joe/target/fileIUp2rF
installing gr-op25
gr-op25 dep [['gnuradio', 'boost', 'libpcap', 'gr-osmosdr', 'libitpp',
'git', 'cmake']]
gnuradio dep [['make', 'boost', 'fftw', 'cppunit', 'swig', 'gsl', 'uhd',
'git', 'python', 'cheetah', 'wxpython', 'numpy', 'lxml', 'pygtk',
'pycairo', 'cmake', 'pyqt4', 'pyqwt5', 'gcc', 'ice', 'git', 'cmake']]
make dep [[]]
swig dep [['python', 'wget', 'gcc']]
mcpp dep [['curl', 'wget']]
curl dep [[]]
wget dep [[]]
cmake dep [['wget']]
libitpp dep [[]]
git dep [['wget', 'curl']]
packages to install: ['libusb', 'uhd', 'pycairo', 'mcpp', 'db48', 'ice',
'gnuradio', 'rtl-sdr', 'osmo-sdr', 'hackrf', 'libosmo-dsp', 'gr-iqbal',
'gr-osmosdr', 'gr-op25']
install called (libusb)
install type priority: ['deb', 'src']
install deb called (libusb)
deb is not available locally
check remote repositories...
PyBombs.sysutils - INFO - deb_exists: Satisfies requirement...found
downloadable version of libusb-1.0-0-dev
CONDUCTING DEB INSTALL
deb install: pkgreq(libusb-1.0-0-dev,None,None)
bash exec (/home/joe/pybombs):: sudo apt-get -y install libusb-1.0-0-dev
[sudo] password for joe:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
 libusb-1.0-0-dev
0 upgraded, 1 newly installed, 0 to remove and 37 not upgraded.
Need to get 156 kB of archives.
After this operation, 895 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ precise/main libusb-1.0-0-dev
i386 2:1.0.9~rc3-2ubuntu1 [156 kB]
Fetched 156 kB in 8s (19.2
kB/s)
Selecting previously unselected package libusb-1.0-0-dev.
(Reading database ... 242403 files and directories currently installed.)
Unpacking libusb-1.0-0-dev (from .../libusb-1.0-0-dev_2%
3a1.0.9~rc3-2ubuntu1_i386.deb) ...
Processing triggers for doc-base ...
Processing 1 added doc-base file...
Registering documents with scrollkeeper...
Setting up libusb-1.0-0-dev (2:1.0.9~rc3-2ubuntu1) ...
installation ok via: deb
install called (uhd)
install deb called (uhd)
no deb satisfiers available
install src called (uhd)
state = configure
Current step: (uhd :: make)
make
('\n    make -j4\n', '\n    make -j$makewidth\n')
('\n    make -j4\n', '\n    make -j4\n')
bash exec (/home/joe/pybombs/src/uhd/host/build)::
   make -j4
[ 12%] [ 12%] Built target man_page_gzips
[ 12%] Built target manual_html
Built target doxygen_docs
make[2]: *** No rule to make target `/usr/lib/libusb-1.0.so', needed by
`lib/libuhd.so.003.006'.  Stop.
make[1]: *** [lib/CMakeFiles/uhd.dir/all] Error 2
make: *** [all] Error 2
ERROR:root:PyBOMBS Make step failed for package (uhd) please see bash
output above for a reason (hint: look for the word Error)
Message 1 of 8
(9,112 Views)
Here's script pg 1 (due to char limit)
Loading recipes ...
False
installing gr-op25
'git', 'cmake']]
make dep [[]]
PyBombs.sysutils - INFO - have_deb: Satisfies requirement...installed
version of make (3.81) is >= than 3.75
boost dep [['python', 'libbzip', 'wget']]
fftw dep [['wget']]
cppunit dep [['wget']]
gsl dep [['wget']]
version of libgsl0-dev (1.15) is >= than 1.13
version of libgsl0ldbl (1.15) is >= than 1.13
uhd dep [['make', 'swig', 'python', 'libusb', 'git', 'cmake', 'cheetah',
'boost', 'gsl', 'numpy', 'cppunit', 'fftw', 'git', 'cmake']]
make dep [[]]
python dep [['wget']]
libusb dep [['wget']]
wget dep [[]]
cheetah dep [['python', 'wget', 'python']]
Message 2 of 8
(9,110 Views)
Script pg 2
version of python-cheetah (2.4.4) is >= than 2.0
gsl dep [['wget']]
numpy dep [['python', 'swig', 'wget', 'python']]
fftw dep [['wget']]
wxpython dep [['gtk2', 'python', 'swig', 'wget']]
lxml dep [['python', 'libxml', 'libxslt', 'setuptools', 'wget',
'python']]
version of python-lxml (2.3.2) is >= than 2.3.2
pygtk dep [['python', 'swig', 'gtk2', 'pygobject', 'pango', 'cairo',
'wget']]
version of python-gtk2 (2.24.0) is >= than 2.17
pycairo dep [['cairo', 'python', 'wget']]
cairo dep [['fontconfig', 'libpng', 'pixman', 'x11', 'wget']]
version of libcairo2 (1.10.2) is >= than 1.8.10
wget dep [[]]
pyqt4 dep [['python', 'sip', 'qt4', 'wget']]
version of python-qt4 (4.9.1) is >= than 4.6.2
pyqwt5 dep [['qwt5', 'pyqt4', 'sip', 'wget']]
version of python-qwt5-qt4 (5.2.1) is >= than 5.2
gcc dep [[]]
ice dep [['swig', 'mcpp', 'db48', 'libbzip', 'expat', 'python', 'wget',
'ssl']]
curl dep [[]]
wget dep [[]]
db48 dep [['wget']]
wget dep [[]]
libbzip dep [['wget']]
expat dep [['wget']]
version of libexpat1-dev (2.0.1) is >= than 2.0.1
wget dep [[]]
ssl dep [[]]
libpcap dep [[]]
gr-osmosdr dep [['uhd', 'rtl-sdr', 'osmo-sdr', 'hackrf', 'gnuradio',
'gr-iqbal', 'git', 'cmake']]
make dep [[]]
wget dep [[]]
gsl dep [['wget']]
fftw dep [['wget']]
rtl-sdr dep [['libusb', 'git', 'cmake']]
wget dep [[]]
osmo-sdr dep [['git', 'cmake', 'libusb', 'git', 'cmake']]
wget dep [[]]
hackrf dep [['git', 'cmake', 'libusb', 'git', 'cmake']]
wget dep [[]]
make dep [[]]
fftw dep [['wget']]
gsl dep [['wget']]
make dep [[]]
wget dep [[]]
gsl dep [['wget']]
fftw dep [['wget']]
'python']]
'wget']]
wget dep [[]]
gcc dep [[]]
'ssl']]
curl dep [[]]
wget dep [[]]
db48 dep [['wget']]
wget dep [[]]
wget dep [[]]
ssl dep [[]]
gr-iqbal dep [['gnuradio', 'libosmo-dsp', 'git', 'cmake']]
make dep [[]]
fftw dep [['wget']]
gsl dep [['wget']]
make dep [[]]
wget dep [[]]
gsl dep [['wget']]
fftw dep [['wget']]
'python']]
'wget']]
Message 3 of 8
(9,109 Views)
and finally pg 3
wget dep [[]]
gcc dep [[]]
'ssl']]
curl dep [[]]
wget dep [[]]
db48 dep [['wget']]
wget dep [[]]
wget dep [[]]
ssl dep [[]]
libosmo-dsp dep [['fftw', 'autoconf', 'libtool', 'automake', 'git']]
fftw dep [['wget']]
autoconf dep [[]]
libtool dep [[]]
automake dep [[]]
libitpp dep [[]]
 libusb-1.0-0-dev
kB/s)
state = configure
make
   make -j4
Message 4 of 8
(9,108 Views)
Hello Joe,
Could please you specify what USRP hardware you are using?
Matthew R.
Field Applications & Systems Engineer
Message 5 of 8
(9,078 Views)
Hey Joe,
I believe the OP25 forum was slightly mistaken.  This forum is targeted to providing support for LabVIEW and NI-USRP driver, or questions related to USRP hardware.  For UHD specific support, please use the UHD and GNURadio mailing lists.  You can find information about the mailing lists here, under the Help and Support header:
http://code.ettus.com/redmine/ettus/projects/uhd/wiki
The wiki also has some general instructions to help step through the installation process.
Sarah Yost
Senior Product Marketing Manager
Message 6 of 8
(9,075 Views)
Hi Matt,
I don't have USRP yet but plan on buying it once I get all software up and running. I think I may be in the wrong forum unless you can help here. I will post my question on the usrp-users forum once I am approved.
Message 7 of 8
(9,070 Views)
Thanks I just requested access to the usrp-users forum
Message 8 of 8
(9,069 Views)
