USRP Software Radio
USRB B210 for Phased Array System
I am trying to create a testbed for digital beamforming using two or more antenna. I am very new in this field so I have some question.
------Is it possible to create a 2 antenna array using B210 alone?
------Can more than 2 antenna array be developed using multiple B210? If yes can it be synchronized using MIMO cable or external clock is required?
-------Is it compatible with GNU radio or LabView?
-------What other accessories may be needed with B210 for phased array system?
-------Can we use our own custom made antenna with B210?
(2,912 Views)
hello..
I will also do the same research as you, have you done this experiment? and did it work?
(762 Views)
