USRP Software Radio
USRP 2900 56MHz instantaneous bandwidth access
hi to all.
i am working on NI USRP 2900. have tried 2017 to 2019 Labview to access its full bandwidth but i cant access more than 10MHz instantaneous bandwidth. i want to design a system of spectrum monitoring in specific bandwidth. NI 2900 suits me
Anyone has used its full bandwidth. anyone can guide me.
USRP  configuration utility has shown its connection over USB3.
Regards
Ali
(2,229 Views)
Could you try to use a simple shipping Rx example to check 10 MHz instantaneous BW or IQ rate?
The overflow error means that your Rx logic is slow to get the next fetch data from USRP. I guess that niUSRP rx fetch data.vi and the additional processing logic are in a single while-loop.
(2,160 Views)
