USRP Software Radio
USRP 2932 firmware
I have exactly the same problem with an USRP2922, NI-USRP 1.2 driver and Labview 2013.
Did you identify the cause and resolve the problem ?
Adrien
Message 11 of 29
(5,182 Views)
are there any news regarding this problem you can share with us?
Message 12 of 29
(5,145 Views)
Thank you for your input on this forum so far. National Instruments has reproduced this issue and has identified the problem. We are currently testing the solution to establish full functionality. If you are having similar issues to those expressed in this forum and need immediate assistance, please contact National Instruments support.
Thank you,
Eric-E
Message 13 of 29
(5,119 Views)
    I am using NI USRP 2922 with NI USRP Software Suite 1.2 Installed, Images loaded to USRP 2922 are,
Firmware Image: ni292x_fw.bin
FPGA Image: ni292x_fpga.bin
I am just trying to run ni USRP EX FM Demod Sound Card (Shif Registar.vi which will be shipped as example VI.
The screen shot of error is attached.
Thanks & Regards,
Rak**bleep**h Jain
Application Engineer
Starcom Information Technology Ltd
(NI India Academic Partner)
Message 14 of 29
(5,065 Views)
I experienced the same error when trying to run an example using USRP 2922. Anyone got the fix? NI USRP error.png
Message 15 of 29
(4,953 Views)
Hey bruceleow,
Can you confirm that you have NI-USRP version 1.2 installed?  Support for the 2922 and 2932 were added to the driver in version 1.2 and I would expect to see this error if you are using version 1.1 or below.  You can download version 1.2 on our drivers page:
http://www.ni.com/download/ni-usrp-1.2/3696/en/
Sarah Yost
Senior Product Marketing Manager
Message 16 of 29
(4,944 Views)
Hi Sarah,
Yes, the driver installed is version 1.2. I am using the Labview 2013 SP1.
Message 17 of 29
(4,940 Views)
Hi Sarah,
Any update regarding the fix?
Message 18 of 29
(4,897 Views)
Hello All,
National Instruments has found and resolved an issue with select USRP models that result in the following error message:
Error -1074118627 occurred at niUSRP Initiate.vi Possible reason(s): A runtime or configuration error occurred. Code: 2410 Details: LookupError: Path not found in tree: /mboards/0/dboards/A/rx_frontends/0/sensors/lo_locked
If you see the above error please contact National Instruments support line: 1-866-ASK-MyNI, and an Applications Engineer will help you resolve this issue.
Best Regards,
Jignesh Patel
RF and Baseband Product Support Engineer
Best Regards,
Jignesh Patel
Principal RF Software Engineer
Message 19 of 29
(4,881 Views)
I am having the same problem and I need your assistance please
Message 20 of 29
(4,172 Views)
