USRP Software Radio
USRP 2974 FPGA Not discoverable in Vivado Over JTAG
Hi All
Does anyone know the resolution to this issue?
https://github.com/EttusResearch/uhd/issues/388
Gary
(1,836 Views)
Hello.
It is not recommended to run an older Vivado on a recent OS, instead use a more recent Xilinx Vivado Lab release, or use a slightly older OS version -- for example via a virtual machine (VM).
In order to use the JTAG interface, you will need to install the Digilent Cable Driver. It is included with the Xilinx Vivado Lab Edition package.
Navigate to the folder /opt/Xilinx/Vivado_Lab/2015.4/data/xicom/cable_drivers/lin64/install_script/install_drivers, and run the installer script.
 cd /opt/Xilinx/Vivado_Lab/2015.4/data/xicom/cable_drivers/lin64/install_script/install_drivers
   sudo ./install_digilent.sh
Find instructions in the bellow:
X300/X310 Device Recovery - Ettus Knowledge Base
Regards.
(1,572 Views)
