USRP Software Radio
USRP E312 stops transmission
Hi, i've been looking for a solution to a problem which exactly the same I've written below. I tried to use nohup but i failed again. Does anybody have an idea? Thanks.
http://lists.ettus.com/pipermail/usrp-users_lists.ettus.com/2018-May/056759.html
(2,398 Views)
Did you try the solution proposed in that thread?
Sam R.
(2,241 Views)
I couldn't use "nohup" command properly i guess. Now i'm trying to reach rc.local file.
(2,234 Views)
