USRP Software Radio
USRP MATHEMATICS
what is usrp block chain for transmitting side ? and mathematically  what happen to signal in each stage for real and complex signals ? and if the input baseband signal for usrp transmitter larger than [-1 1]  what happen and what is the solution to make the signal proper as input in this case?
thanks
(2,524 Views)
if you want to get an idea of the USRP transmission chain, I suggest you to take a look at the examples contained in the LabVIEW palette you can reach selecting Express -> Output -> Instrument Drivers -> NI-USRP -> Examples (niUSRP), available after installing NI-USRP. The example named niUSRP EX Tx Continuous Async.vi, of which I put a snippet below, may be particularly useful to you.
Alessia
(2,377 Views)
