USRP Software Radio
USRP RIO driver failed
I have installed windows 10 and LV NXG 3.1 in a USRP 2974 (standalone host). A USRP 2943 is connected to the 2974. Both the RIO devices have failed to show up in the NI Configuration Utility. I am including the snapshots of
1. Windows device manager,
2. NI MAX devices tab,
3. LV Comms SystemDesigner.
All of which shows that the USRP Driver failed although I have USRP 19.1 installed. Is there any issue with the PCIe drivers for windows?
(2,387 Views)
Hi melahi,
You need to install NI RIO driver as well, and the driver can be found here. Another thing that you can try is to make sure that the USRP is powered on first before power on the computer.
Kindly let me know if this works for you. Thank you.
Best Regards,
Kingsley Chan
(2,302 Views)
May I know if the proposed solution works for you? Kindly let me know if you have any question.
Looking forward for your reply.Thank you.
Best Regards,
Kingsley Chan
(2,280 Views)
