USRP Software Radio
USRP Residual Carrier for Phase Correction
Hello I am trying to create an advanced receiver of PSK signals.
I would like to seperate the process that are done in the demodulator (Lab 4  Demodulation VIs [LV 2012 USRP 1.2]).
I would like to match filter my incoming signal, do frequency correction, and phase correction without a symbol map input.
I would like to add a residual carrier to my transmitted signal and then use this sine wave to have correct phase information for the demodulator.  Is this possible how would I do this?
also does anyone have a 8psk soft demodulator?
(5,774 Views)
Here is an example showing how to perform phase and frequency offset correction:
https://decibel.ni.com/content/docs/DOC-26873
Could you explain a little bit more about what you are trying to accomplish with the residual carrier?
James K.
(5,760 Views)
