USRP Software Radio
USRP X310 programming : RuntimeError: Device reported an error during initialization.
I get the error mentioned in the title when I try and run UHD_images_loader for my USRP X310. Error message below. I've tried uploading a bitstream file to the FPGA over the USB JTAG using Vivado. UHD_find_devices and UHD_probe both report no errors when I do this, but when I try and upload the image to the non-volatile memory, the following error occurs. Any suggestions?
Many thanks
C:\Program Files\UHD\bin>uhd_image_loader --args="type=x300"
[INFO] [UHD] Win32; Microsoft Visual C++ version 1942; Boost_108500; UHD_4.8.0.0-release
Unit: USRP X310 (31F3C5A, 192.168.10.2)
FPGA Image: C:\Program Files\UHD\share/uhd\images\usrp_x310_fpga_HG.bit
failed.
Error: RuntimeError: Device reported an error during initialization.
(581 Views)
Hello jamfletch,
In the first line of the error:
should the "type" be x300 or x310? Can you try them both?
Also, I just noticed: your FPGA Image link says "\share/uhd\", I hope that's a typo since "\share\uhd\" makes more sense.
Let me know what you find!
Messenger2
Messenger2
If someone's answer helped you find a solution or provided insight into an issue, the best way to show your appreciation and acknowledgement is by giving them a kudo or marking their reply as a solution.
(538 Views)
