USRP Software Radio
USRP X410, runtime error: Graph edge list is empty for tx channel 0
I have a new Ettus X410 USRP. I updated it successfully step by step based on:
Ettus USRP X410 Getting Started Guide - NI
then when in the LabVIEW I run example "niUSRP EX Tx Continuous Async.vi" as guide says, I receive this error:
niUSRP Configure Signal.vi<ERR> A runtime or configuration error occurred.
Code: 1359
Details: RuntimeError: Graph edge list is empty for tx cannel 0.
also, I see at the error out display this code: -1074118627
I have the same error when I run the RX example "niUSRP EX Rx Continuous Async.vi".
BTW, I can run uhd_find_devices and uhd_usrp_probe command successfully.
I connect USRP directly to my laptop (I set static IP address for both USRP and my laptop, through editing /data/network/eth0.network file), and can ping USRP.
I have antenna on TX/RX0 and RX1 of first channel in the left side of USRP.
for Device name I enter the USRP IP address.
for Active antenna, I enter the TX/RX0 and RX1, for TX and RX examples, respectively.
I am using LabVIEW version 2022 Q3 (64bit) 22.3.1f8 and usrp_x4xx_fs_v4.3.0.0.mender
Would you please help?
(4,151 Views)
Accepted by topic author ni_hj
If you follow the guides and still have this error, do this to solve it:
uhd_image_loader --args type=x4xx,addr=127.0.0.1,fpga=X4_200
(3,949 Views)
