USRP Software Radio
USRP X410 unreachable
My device is a USRP X410. When I tried using uhd_find_device, I encountered the following results. I attempted three methods: performing a factory reset with usrp_update_fs, updating the file system with the mender system, and directly refreshing the eMMC, but all resulted in 'unreachable.' I can SSH into the internal system of the USRP, which indicates that the network connection should be fine.
Please help me; I’m overwhelmed by this issue
(634 Views)
Hello Sliverfish0829,
you wrote that your USRP X410 is 'unreachable' after you updated the device, but also that you can still SSH into the internal system of the USRP.
Could you share what the network configuration of the USRP is (output of command 'ifconfig'), and the host system (on which you run uhd_find_devices) are?
Could you also share some details of the network setup between your host and your USRP X410, like do you use a 10/100 GbE network card directly cabled to the USRP QSFP28 port or do you use a network switch and communicate via the USRP 1GbE interface?
Regards
(594 Views)
