08-01-2012 11:31 PM
When I use the wire to connect pc with ni-usrp 2920,the computer displayed "the cable has disabled" like I didn't put the wire into the computer.When I use the NI-USRP Configuration Utility ,it couldn't find the device.
I followed the proceduce and changed the ip address,but it just doesn't work.Can someone help me solve the problem?
My computer is Compaq Presario CQ40-509AU,it has a gigabit ethernet ,
08-02-2012 03:05 PM
Hello llg9012,
Could you please answer a few questions:
08-02-2012 07:57 PM - edited 08-02-2012 08:06 PM
Hi,Anthony F
1.The USRP is connected directly to my computer.
2.Only D&F are turned on,the left are all off.When the USRP is turned on,A C E only blinked a little while,then it turned off.
3 the network card work when connected to regular network,can access internet/network resources.
I just use the computer to reply to you,it obviously says the network card work is OK.
When I choose to connect the computer with the USRP,the computer just shows the network cable has been extracted. and only D&F lights on USRP are on.It seems they just don't know each other.
08-02-2012 08:26 PM
In addition,When USRP started,the orange light blinked a little while,then it turned off,the green light never turned on,
08-02-2012 11:23 PM
08-05-2012 01:55 AM
Thank you!
08-05-2012 10:33 AM
hi all,
this is situation:
Ethernet port was set to statis IP and ethernet controller supports Gb. USRP device was connected to PC with Gb cable
that comes with device. USPR drivers is instaled.
i did everything that was suggest in GETTING STARTED GUIDE NI USRP -292x, and still, USRP utilities does not detect the device....
Is there any way to solve this?
08-05-2012 11:02 AM
can you describe the light sequence on the ABCDEF lights? when booted there should be some flashing and the bottom two lights on the right hand side should be illuminated. Is this the case?
Does the light come on on the ethernet plug on the USRP? Does the computer say "etherent cable disconnected" or some other message?
Thank you,
Erik
08-05-2012 11:19 AM
ErikL,
D and F are green ,in bothom right corner of ABCDEF lights. LED at gb ethernet port is green non-stop, and somethimes
orange light apeers at the other side of the GB ethernet port. PC doesen't say anything like cable disconected, just connect at start
and nothing more...
thank ypu,
pixus
08-07-2012 11:33 AM
Pixus, we are moving your discussion to your thread located at:
Re: Does enyone know where i can find driver's for NI USPR 2920?
