USRP Software Radio
USRP configuration problem: cannot change FPGA image NI2901 to Ettus B210
hello all,
-> How can I change NI 2901 FPGA image to Ettus B210 with problem below?
I want to use NI 2901 on GNUradio/UHD.
Cause driver of the device is checked NI-USRP, I need to recognize the device as Ettus B210.
So I'm trying to change FPGA image refer to https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIJJCA4&l
But when I select my device, then I CAN'T select/browse FPGA image (button becomes disabled)
I registered the device properly via NI homepage and this USB device is connected on USB3 port.
and the device is connected power supply for it.
(OS: windows 10)
(2,655 Views)
Hi yoowj,
Just want to check if you are able to view the FPGA images files in your folder.
The path is =>  C:\Program Files (x86)\National Instruments\NI-USRP\images
(2,392 Views)
1. Have you tried to reinstall the NI-USRP driver and check if the files are located in the folder?
2. Have you referred to the USRP-2901 manual on setting up the device?
Suppose if the installation is done, you should be able to find the required files.
Please let me know if you still facing the issue.
(2,384 Views)
