USRP Software Radio
USRP frequency measurement
hello everybody,
I am working on a project with USRP (USRP2930) and i would like to measure a frequency.
So, In my project, my USRP Card 2930, is in reception (RX) and i gernerate a signal with signal generator.
I want to measure with my usrp card the carrier frequency that I generate. is it possible? can you help me please ?
in the drivers, each time it is necessary to inform the frequency of the expected signal, but I want to measure this frequency and not to tell the usrp that the signal is at this carrier frequency.
Thanks you
Mathias
(3,723 Views)
Hello mathias19100,
You could calculate the FFT of the incoming signal and do a peak detection to get the carrier frequency.
Have a nice day!
Clement
(3,695 Views)
thanks you Clement for your answer, i am going to try.
But I do not want to say to the card: the signal is at X Hz. the block "configure signal" is it essential for the proper operation of the card? I have the impression that yes, and therefore it is mandatory to enter a carrier frequency to configure the card.
have a nice day
Mathias
(3,688 Views)
Hey Mathias
yes you need to set a carrier frequency, at least a rough one depending on the bandwidth you use for recording your signal. You could also sweep over a frequency range.
But you should also be aware, if you try to search for a real frequency (pure sine) using a FFT, that the FFT will show you the frequency twice, above and below of your carrier.
Max
(3,639 Views)
