USRP Software Radio
USRP
Is it possible to build 16X16 MIMO using USRP? If Yes how many USRP will be required? Is existing IN software supports the same?
(6,051 Views)
16x16 should work fine with the 8x8 MIMO example code, however careful considrations are necessary for both data bus bandwidth and processing capabilies.  These limitations could limit you to very small bandwidths. Please get in contact with your local sales engineer to discuss options using both current and future products.  You may also email niusrp@ni.com for this type of sales related inquiries.
(6,049 Views)
Thanks ErikL.
(6,045 Views)
