USRP Software Radio
USRP
Hi
I'am trying the loop back test with USRP2920
I'm using the RX TX finite synk example VI
but signal received always has a different phase
how this is possible?
is there any solution?
thank you so much
ps
the tx signal is a sin(2*pi*f*t)  0<t<tau
with f=1000Hz     and  tau =0.1s
(6,298 Views)
Hello Fspadafora,
what do you exactly mean with different phase?
Could you please try to explain it a bit more?
Thank you
(6,242 Views)
Accepted by topic author fspadafora
Hi valerio
I solved the problem.. thank you for the interest.
Francesco
(6,238 Views)
Hi Francesco,
We have the same problem as you but we can't solve it. How did you solve the problem?
Thanks!
(4,849 Views)
