USRP Software Radio
USRP
Hi
Can anyone answer this question?
In RXRFconfig.vi the IQ rate parameter is used by niUSRP Configure Signal.vi. Can the USRP support any arbitrary IQ rate? If not, what will the USRP do when an unsupported bandwidth parameter is requested?
Thanks in advance
(5,188 Views)
It will coerce the IQ rate and you can view the coerced rate as an output the VI you specified. http://zone.ni.com/reference/en-XX/help/373380A-01/usrpviref/niusrp_configure_signal/ - gives you further information about this VI.
Kind Regards,
Lucas
(5,091 Views)
